Hi Sang,
Yes, absolutely! You can change the icon that appears on your host devices (phone/PC) by modifying the Class of Device (CoD) parameter of your BT1036 module.
The CoD tells the host device what kind of device it is, and the OS then assigns an appropriate icon.
How to change it:
Use the AT+COD command followed by the 6-digit hexadecimal code for your desired device class.
Examples:
// Set Device Class (COD)
AT+COD=001F00 // Generic Bluetooth device
AT+COD=240404 // Headset device
AT+COD=040680 // Printer device
After sending the command, restart the module or toggle its power. The new icon should appear on your phone's or PC's Bluetooth list upon the next connection.
Finding more CoD codes:
The CoD can be defined for many device types. For a more comprehensive list of codes, you can visit this third-party website:
https://www.ampedrftech.com/cod.htm
We hope this helps! Let us know if you have any other questions.
