Igor For FSC-BT1058, you can determine and configure the A2DP codec settings through the following AT commands.
Please refer to the BT1058 AT command manual:
https://document.feasycom.com/docs/audio/BT1058_EN/latest/index.html
- Configure supported A2DP codecs
Command:
AT+A2DPCFG
AT+A2DPCFG=xxx
Please note that this command only configures the available codec list. The final codec used during the Bluetooth connection is negotiated automatically between the two devices.
- Check the currently used codec
If BT1058 works as A2DP Source (transmitter):
AT+A2DPENC
If BT1058 works as A2DP Sink (receiver):
AT+A2DPDEC
Therefore, if you want to change the codec, please adjust the supported codec configuration using AT+A2DPCFG, then reconnect the Bluetooth device. The final codec will be selected according to the codec support of both devices.
