Baursaque Yes, FSC-BT1026E supports S/PDIF audio output.
S/PDIF can be enabled by AT command:AT+SPDIFCFG=1 ; Disable:AT+SPDIFCFG=0
When S/PDIF output is enabled, I2S configuration will become invalid.
The S/PDIF output pin is:
- SPDIF-OUT: Pin 15
- SPDIF-IN: Pin 16
The S/PDIF output sample rate is adaptive according to the audio stream. No custom firmware is required; the standard FSC-BT1026E firmware supports this function.
More details can be found in the AT command manual:
https://document.feasycom.com/docs/audio/BT1026_EN/latest/index.html
