udom Hi Udom,
Since the same I2S configuration works on BT1026 but not on BT1036, please first check whether the input mode and related audio configurations are the same on both modules.
For BT1036, please confirm the following settings:
- AT+AUXCFG (Input mode)
- AT+I2SCFG
- AT+VER
Please note that the AUXCFG parameter order for BT1036 is different from some other modules:
- 0: USB mode
- 1: Line-in mode
- 2: SPDIF mode
- 3: I2S mode
You can also try resetting the BT1036 to factory settings and then reconfigure the I2S parameters before testing again.
If the issue still exists, please provide the complete configuration commands and responses, and we will help check further.
