James To configure the BT631D as a BIS receiver and connect to your BIS gateway, follow these steps:
Quick Setup Guide:
Set Profile:
First, configure the module for LE Audio headset mode:
AT+PROFILE=17577
Scan for Gateways:
Search for available BIS transmitters nearby:
AT+SCAN=4
The module will list detectable BIS gateways after scanning.
Connect to Gateway:
Use the gateway name from the scan results to connect:
AT+BISCONN=<BISgateway_name>
Key Points:
- Ensure the BIS gateway is powered on and broadcasting before scanning.
- The module will automatically sync to the audio stream after a successful connection.
Let me know if you encounter any issues during setup!
