For the Mee Audio that keeps connecting and disconnecting and never pairing.
in startBluetoothAudio()
BT-TX: AT+ECHO=2
BT-RX: OK
BT-TX: AT+PROFILE
BT-RX: @CMD:AT+PROFILE
BT-RX: +PROFILE=64
BT-RX: OK
BT-TX: AT+AUDROUTE=0
BT-RX: @CMD:AT+AUDROUTE=0
BT-RX: +AUDROUTE=0
BT-RX: OK
BT-TX: AT+BTEN=1
BT-RX: @CMD:AT+BTEN=1
BT-RX: OK
BT-RX: +PWRSTAT=1
BT-RX: +VER=BT1036,V2.8.7,20250428
BT-RX: +PROFILE=64
BT-RX: a2dp_source_set_state,idx[0][0->1]
BT-RX: +A2DPSTAT=1
BT-RX: lib_gap_connectable_control 1
BT-RX: +DEVSTAT=1
BT-RX: app_reconnect_start,null
BT-RX: +DEVSTAT=3
PowerOn Audio OK
BT-TX: AT+MICGAIN=8
BT-RX: [BLUEWARE😮N][NAME:FSC-BT1036][MAC😃C0D300FE9C2][PROFILES:64][RECONNECT:0][Mar 27 2025 00:16:20][BLUEWARE VER:114]
BT-RX: hci_write_scan_enable:result[00],value[3]
BT-RX: @CMD:AT+MICGAIN=8
BT-RX: OK
in startBluetoothAudio: trying to reconnect to last connected
BT-TX: AT+A2DPCONN
BT-RX: @CMD:AT+A2DPCONN
BT-RX: OK
BT-RX: app_reconnect_attempt 000BD5E82F3D |A2DP-SRC|
BT-RX: btAPI_A2DP_SRC_Connect
BT-RX: set_signal_state[0]=0:1
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:2372
BT-RX: a2dp source conn :000BD5E82F3D
BT-RX: a2dp_source_set_state,idx[0][1->2]
BT-RX: +A2DPSTAT=2
BT-RX: CM:000BD5E82F3D
BT-RX: CONNECTING😐A2DP-SRC|
BT-RX: hci create connection,00,000BD5E82F3D
BT-RX: +AUDMODE=0
RX_AUDMODE = 0
BT-RX: HCI_EVENT_CONNECTION_COMPLETE =0x04,000BD5E82F3D
BT-RX: acl[1]:000BD5E82F3D,connected:0,reason:0x04
BT-RX: HCI_CONN_FAILED:000BD5E82F3D,reason:04
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x4,addr=000BD5E82F3D,handle=0x0000,psm=0x0019,lcid=0x0041,rcid=0x0000,lMtu=512,rMtu=512
BT-RX: set_signal_state[0]=1:0
BT-RX: SRC:BLUEWARE_A2DP_CLOSED_IND:000BD5E82F3D,reason:04
BT-RX: a2dp_source_set_state,idx[0][2->1]
BT-RX: +A2DPSTAT=1
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:3260
BT-RX: +A2DPSTAT=2
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x4,addr=000BD5E82F3D,handle=0x0000,psm=0x0019,lcid=0x0042,rcid=0x0000,lMtu=512,rMtu=512
BT-RX: +A2DPSTAT=1
BT_UART_TX_ConnectOnLastDevice: Failed: 1.
BT-RX: F3D
gBluetoothHeadsetsPairedSize = 0, gBluetoothHeadsetsFoundSize = 0
BT-TX: AT+SCAN=1
BT-RX: can_enable:result[00],value[0]
BT-RX: hci_inquiry:00
BT-RX: inquiry_flag:1
BT-RX: +SCAN=1,-116,0,534A52F40C7A,MEE audio BT3,2C4404
BT-RX: hci_inquiry_complete_handle,status:00
BT-RX: BLUEWARE_INQURIY_SCAN_COMPLETE_IND:00
BT-RX: +SCAN=E
gBluetoothHeadsetsPairedSize = 0, gBluetoothHeadsetsFoundSize = 1
Found device list index 0, 534A52F40C7A, MEE audio BT3
BT-RX: +DEVSTAT=1
BT-RX: inquiry_flag:0
BT-RX: +DEVSTAT=3
BT-TX: AT+A2DPCONN=534A52F40C7A
BT-RX: @CMD:AT+A2DPCONN=534A52F40C7A
BT-RX: OK
BT-RX: app_reconnect_attempt 534A52F40C7A |A2DP-SRC|
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:5227
BT-RX: a2dp source conn :534A52F40C7A
BT-RX: +A2DPSTAT=2
BT-RX: CM:534A52F40C7A
BT-RX: hci create connection,00,534A52F40C7A
BT-RX: HCI_EVENT_CONNECTION_COMPLETE =0x00,534A52F40C7A
BT-RX: current role is master
BT-RX: BLUEWARE_HCI_ACL_CONN_CHANGED_IND 1,534A52F40C7A
BT-RX: app_stop_linker,1000
BT-RX: CONNECTED😐ACL|
BT-RX: acl[2]:534A52F40C7A,connected:1,reason:0x00
BT-RX: BLUEWARE_HCI_CONN_NR_CHANGED_IND 1
BT-RX: BLUEWARE_HCI_REMOTE_NAME_REQUEST_IND 00
BT-RX: HCI_EVENT_REMOTE_NAME_REQUEST_COMPLETE:0
BT-RX: BLUEWARE_GAP_PAIR_USER_CONFIRM_REQ_IND,addr:534A52F40C7A,numberic:287842
BT-RX: +PAIRREQ=287842,534A52F40C7A,MEE audio BT3
BT-RX: BLUEWARE_GAP_SIMPLE_PAIR_RESULT_IND 00
BT-RX: +PAIRED=0,534A52F40C7A,MEE audio BT3
openRemoteEndpoint: Success.
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x0,addr=534A52F40C7A,handle=0x0032,psm=0x0019,lcid=0x0044,rcid=0x00c4,lMtu=512,rMtu=672
BT-RX: set_signal_state[0]=1:2
BT-RX: libMessageSendLater avdtp_src_discover_timeout:0
BT-RX: AVDTP:avdtp_src_discover_timeout 0 2 0 0
BT-RX: set_signal_substate[0]=0:1
BT-RX: avdtp_send_cmd:1
BT-RX: avdtp_signalling_response:0,status:0x00
BT-RX: avdtpProcessResponse:01,accept:1
BT-RX: [hex]:seid-info,size:14
BT-RX: 12 01 28 08 1C 08 24 08 20 08 18 08 14 08
BT-RX: media_type=0 tsep=1 ptr[0]=40
BT-RX: media_type=0 tsep=1 ptr[0]=28
BT-RX: media_type=0 tsep=1 ptr[0]=36
BT-RX: media_type=0 tsep=1 ptr[0]=32
BT-RX: media_type=0 tsep=1 ptr[0]=24
BT-RX: set_signal_substate[0]=1:2
BT-RX: avdtp_send_cmd:2
BT-RX: avdtpProcessResponse:02,accept:1
BT-RX: ities,id:01,0a
BT-RX: ##remote_capabilities,id:07,ff
BT-RX: ##remote_capabilities,id:04,00
BT-RX: ##avdtp_get_capabilities failed,try seid:9
BT-RX: ##remote_capabilities,id:01,0d
BT-RX: ##avdtp_get_capabilities failed,try seid:8
BT-RX: ities,id:01,08
BT-RX: ##remote_capabilities,id:07,02
BT-RX: set_signal_substate[0]=2:0
BT-RX: SRC:BLUEWARE_A2DP_CLOSED_IND:534A52F40C7A,reason:00
BT-RX: +A2DPSTAT=1
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=0044,reason:13,addr:534A52F40C7A
BT-RX: set_signal_state[0]=2:0
BT-TX: AT+PLIST
BT-RX: @CMD:AT+PLIST
BT-RX: +PLIST=1,0,534A52F40C7A,MEE audio BT3
BT-RX: +PLIST=2,64,000BD5E82F3D,JABRA DRIVE
BT-RX: +PLIST=E
gBluetoothHeadsetsPairedSize = 2, gBluetoothHeadsetsFoundSize = 1
LinkKey list index 0, 534A52F40C7A, MEE audio BT3.
LinkKey list index 1, 000BD5E82F3D, JABRA DRIVE.
BT-RX: OK
BT_UART_TX_getPLIST (Pair Mode): Success.
BT-RX: BLUEWARE_HCI_ACL_CONN_CHANGED_IND 0,534A52F40C7A
BT-RX: BLUEWARE_HCI_CONN_NR_CHANGED_IND 0
BT-RX: C7A
BT-RX: UEWARE_HCI_CONN_NR_CHANGED_IND 1
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x0,addr=534A52F40C7A,handle=0x0032,psm=0x0019,lcid=0x0046,rcid=0x0146,lMtu=512,rMtu=672
BT-RX: capabilitote_capabilities,id:04,00
BT-RX: :534A52F40C7A
BT-RX: ONNECTING😐A2DP-SRC|
BT-RX: acl[2]:534A52F40C7A,connected:1,reason:0x0set_signal_state[0]=1:2
BT-RX: 1 ptr[0#remote_capabilities,id:07,ff
BT-RX: ##remote_capabilities,id:01,09
BT-RX: ##avdtp_get_capabilities failed,try seid:6
BT-RX: TED😐ACL|
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=0048,reason:13,addr:534A52F40C7A
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:7052
BT-RX: +A2DPSTAT=2
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x0,addr=534A52F40C7A,handle=0x0032,psm=0x0019,lcid=0x004a,rcid=0x024a,lMtu=512,rMtu=672
BT-RX: capabilities,id:01,0a
BT-RX: ##remote_capabilities,id:01,08
BT-RX: +A2DPSTAT=1
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=004a,reason:13,addr:534A52F40C7A
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:7642
BT-RX: +A2DPSTAT=2
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x0,addr=534A52F40C7A,handle=0x0032,psm=0x0019,lcid=0x004c,rcid=0x02cc,lMtu=512,rMtu=672
BT-RX: capabilities,iapabilities,id:04,00
BT-RX: +A2DPSTAT=1
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=004c,reason:13,addr:534A52F40C7A
BT-RX: C7A
BT-RX: UEWARE_Hate[0]=1:2
BT-RX: s:0x00
BT-RX: A52F40C7A
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=004e,reason:13,addr:534A52F40C7A
BT-RX: libMessageSendLater avdtp_src_signal_timeout:0,timestamp:8823
BT-RX: +A2DPSTAT=2
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_OPENED_IND,status=0x0,addr=534A52F40C7A,handle=0x0032,psm=0x0019,lcid=0x0050,rcid=0x03d0,lMtu=512,rMtu=672
BT-RX: 1,0d
BT-RX: A52F40C7A
BT-RX: AVDTP:BLUEWARE_L2CAP_CHAN_CLOSED_IND,cid=0050,reason:13,addr:534A52F40C7A
