listenNtalk Hi there,
Thanks for the detailed report. To help us troubleshoot, please check the following:
1. AirPods & JVC HA-A7T2 – paired but no audio
After connection, have you sent AT+AUDROUTE=1? This command routes A2DP audio to the headphones. If not, please try it and let us know the result.
2. Mee Audio BT3 – fails to pair
Please enable verbose logging before pairing: send AT+ECHO=2, then attempt to pair and capture the full UART log. Share the log with us for analysis.
3. Additional info needed
- The exact firmware version strings (e.g., from
AT+VER).
- A brief description of your hardware setup (development board or custom PCB?).
Once we have the logs and details, we can dig deeper.
