Boris We confirm that all modules in the FSC‑BT1026 series (including versions A/B/C/D/E/F) support only A2DP Sink (receiver) mode in the standard firmware.
They are designed for applications such as Bluetooth speakers or audio receiver boxes, and do NOT support A2DP Source (transmitter) mode – meaning they cannot stream audio from the module to a Bluetooth headset or speaker.
Regarding the AT command set you mentioned: although the A2DP Source option appears in the command list, this command set is based on a universal framework for multiple module series. This option is not available/valid on the BT1026 series.
If you could share your specific application scenario (for example, do you need to transmit audio from a TV/PC to headphones, or for another use?), we would be happy to recommend a more suitable module for your needs.
