Hello,
I am looking into have a bluetooth speaker that supports stereo operation. The 2nd speaker can be connected to the 1st one via Auracast, while the primary speaker is connected via regular BT A2DP to a phone.
Which module is better in this case: BT1058 or BT1104?
I see that BT1058 is using a headset chip QCC5xxx while the BT1104 is using a BT speaker chip QCC3xxx.
If I use BT1104 and the speaker handles phone calls, is there noise cancellation that is enabled?
Is BT1058 going to work better (cleaner voice during a call) in this use case?
Can you provide a programming / API documentation?
