Boris Hello, Gavin! I have an FSC-BT1058 module, which, as far as I understand, is configured to work with the built-in antenna. How can I reconfigure it to work with an external antenna connected via the U.FL/Ipex1 connector?
FAE_Gavin Boris This component is a 0Ω resistor (shown in the figure below). You can connect to different external antenna interfaces by modifying the position and orientation of this resistor as follows: To connect the RF_OUT pin (Pin 51) to the external antenna, this resistor must be soldered horizontally. For more detailed information, please refer to the FSC-BT1058 Datasheet
