aschnetz Based on your description, after modifying the iBeacon UUID using the FeasyBeacon App on an iOS device, you found that the UUID became all zeros upon reconnecting. This typically indicates that the new UUID was not accepted or saved by the device.
The UUID you provided (11111111-1111-1111-1111-111111111112) is a valid 128‑bit UUID (32 hexadecimal characters + 4 hyphens) in terms of format. Therefore, the issue is likely related to the writing process or the device’s response.
To help us identify the root cause, could you please record a video (or provide detailed screenshots) of the following steps:
- Open the FeasyBeacon App and connect to the device – show the initially displayed UUID.
- Modify the UUID and tap the save/write button.
- Show any prompt or message displayed by the app after saving.
- Disconnect and then reconnect to the device – check whether the UUID has become all zeros.
Please send the video to: Support@feasycom.com
We look forward to your recording and will assist you as soon as possible.
